Greetings from Australia!
Somewhere on the net is a site showing how to make the turnbuckles on a biplanes rigging. The one I saw used twisted copper wire. Does anyone know the address of any sites of this type?
Thankyou
Celestialsphere
Thankyou
Celestialsphere
Thanks for that, Killercurt.
I’ve also found this article at ipmsstockholm.org:
http://www.ipmsstockholm.org/magazine/2001/11/stuff_eng_tech_rigging.htm
Celestialsphere
check out the latest issue of the GSM 2005. ( if not that one it might be in april fsm)it has the cover with “60 dioramas” or something like that, and it has a great closeup picture of a bipe w/ turnbuckels, a little different style. i made a few like that out of 3/32 brass tube and a dremel w/ the smallest engraving bit. i also experimented w/ the same tube but i flattened the ends and drilled holes in those flat areas. hope this helps.
also check out [www.theaerodrome.com]
