BF109E
I have been lead to believe that the BF109 had a panel line running along the spine of the fuselage, is this true, also is there one along the bottom too?
The 109 did have a panel line along the spine & belly of the aft fuselage. I usually don’t attempt to show it because it requires scribing along a glued joint, or otherwise compromising the strength of the join.
Regards, Rick
