[View:/themes/fsm/utility/
:550:0]
My first attempt at ‘effects and techniques’ BF109 Airfix 1:32
What techniques were you attempting on this build?
I have no knowledge of techniques to the degree you old hands know. In fact I’ve not done a kit since I was 15 years old, a long long time ago. Even back then I knew nothing of spraying, weathering etc…
As a result everything is trail and error and humble enough to know when something hasn’t worked and listen to constructive critiscm.
Ok, that said.
This came out, and I am very pleased with the finish,as a result of laying a primer coat, white enamel,a splinter cam pattern and then covering whilst still tacky, in desert yellow. This led to a cracked paint effect whether I wanted it to or not.
i like it .
Ron
Hard to really gauge by the picture clarity but the color shade seems about right. Bumpy runway there.
well if its your first fir a long time…welcome back…looks good…it will only get better from here…we are all here to help…looks like brush painted…??? recommend to start experimenting with air brushing…once you start you never go back…good job!!!
