This is the Monogram Pro-Modeler boxing of the Hasegawa 1/32 Bf 109G-4. Painted in Aeromaster and Gunze acrylics, EagleCals decals and Eagle Parts resin spinner, only other after market were some Eduard pre painted seat belts. Really a nice kit to build, no problems at all other than the ones induced by my twelve left thumbs.
This plane was flown by Fw. Hans Waldmann in June 1943 from Anapa, Russia.
Thanks for the comments! You cannot go wrong with EagleCals, they’re printed by Microscale so the quality is great and Jerry Crandall’s research is pretty much flawless. The instruction sheets are full of useful information and a reference in themselves. Can you tell that I’m a fan?
Great job, as always, herr Waffle… All it needs is a pilot and a guy hand-cranking the flywheel, and that bird looks like it’ll taxi right outta there…
Another stunning 109 from your bench Mike, you are a serious 109-a-phile! You mention your 12 left thumbs, AAACCCKKK! Sure doesn’t look like it in the photos. That really is a gorgeous build.
And I second the kudos on the EagleCal decals, they really are that good!
Thanks! I believe the two spots is where some previous markings were over painted. Waldmann was a member of the Gruppenstab prior to be assigned to 6. Staffel so this aircraft probably had a chevron and number applied previously.
How do you guys get your antennae wires to look so good?..I really like how detailed they are…I can’t seem to find a reference. I get the wire portion, but the attached areas are superb.
Hutch, I use some stuff called EZ Line for the antennas, really good stuff. It’s kind of flexible too so you won’t break it if you accidentally bump it (like stretched sprue). I just use a drop of CA glue to hold it in place.
Thanks…I see you probably use a drop of white glue for the insulation, but I like the way you depicted the connections to the aircraft. Thanks for the tip on the EZ…I have seen references to it, but have not experimented with it yet…again, fantastic job on your 109…
In regards to the white rudder, is this based on a photo? White rudders would be very uncommon on an Eastern front aircraft and I don’t think I’ ve ever come across a photo of a plane from JG 52 ever marked in this way.
