best reperator
i need to know what the best reperator is. will it be enough to keep me safe if im working in an enclosed room with a fan?[|)]
I don’t know if they call them “two stage” or not. But what you want is one that has a cotton outer filter and a charcoal second stage. The charcoal is what removes the toxic fumes. The cotton gets the particles. I don’t know where you live, but if you’re in the States you can get one at Sears for $36.
Good luck
Dave
[quote]
Good luck
Dave
[/quote
thank u[;)] i wouldnt want to turn my brain into jello
Be aware that cartridge type respirators are only as good as the cartridge that is installed. There is no such thing as a one type fits all when it comes to filters. You must use the proper cartridge that will specificly filter out the particles you are exposed too. A Organic Vapors cartridge should take care of any paint or glue fumes.They don’t last forever either. They will become saturated over time. This depends on frequency of use, respiration rate, humidity and the amount of vapors in a confined space. With that in mind, have fun and be safe.
Darren
thanks. how can u tell if it is saturated?
Good question,
Sorry that I left that part out. With the mask on and no leaks around your face ( A good seal in other words) you will notice that you can smell the vapors your trying to filter out. If you are wearing the mask properly, you should never smell any outside odors.
Darren
thanks[8D]
It is important to keep the organic vapour cartridge sealed in a bag when not in use, otherwise the charcoal will go on soaking up vapours all the time, and quickly become saturated.
You can find several styles of respirator at your local hardware store with appropriate replacement filter cartridges as well. Talk to the guys in the paint dept. They can steer you to the best quality/most cost-effective design.
[:X]gay
ok thanks
my stupid brother put the [:X]gay, sorry.
