Best putty?
Hi there
First post [:I]
I’ve just recently picked up this hobby again after a long break (5 years).
My main interest is in custom cars - Hot Rods, Leadsleds etc. which almost always demands some kind of body modifications. So a good putty is important!
I’m reading Scale Auto and the writers always mentions Evercoat putties BUT - I live in Denmark and havent been able to find it anywhere (I havent even found any on-line stores that would ship it to DK)
So here is my question - finally [;)] :
Are there any putties available in Europe, Scandinavia that is just as good? Its of course very important that it is easy to work with and doesnt sink over time, since some models will get a fair amount of putty…
Whats your opinion?
I use Squadron White and Green puty… Can you get those there?
I dont know - I havent seen them, but I’ll try to search for them.
Is it modeling putty or is it for real-size cars?
Does it air-dry or cure with a hardener?
Tamiya makes putty. It’s quite expensive, so it’s probably not bad.
Try a body shop supply store and ask for “Wurth finishing filler” I know the Wurth brand is available there and they make an excellent two part fine grain filler for small scratches, etc. on 1/1 cars. The Wurth stuff comes out of Germany but is distributed worldwide. It comes in a tin.
Try it and you will never go back to an air dry type filler.
Rick
Thanks - I’ll try to get hold of that [:)]
I use Elmer’s Carpenter interior Wood Filler. It may be available in Denmark. It works quite well, doesn’t shrink and excepts paint with no problems.
I agree with using a catalyzed autobody putty, but a word of caution: most Scale Auto authors recommend using a respirator when you sand these putties, but they say nothing about the smell. These things STINK! I guess it should have been common sense, but I found out the hard way. Use it in a well ventilated area, and wear your respirator when you use it!
As far as Evercoat, your best bet is probably just to order it over the net. Do a Google for it, and you should find a site that sells it.
Adam Howard
I use regular-ol’ Bondo brand glazing and spot putty. Looks, feels, and smells to me exactly like Model-Master putty. It’s even in the same size tube.
I’m kind of partial to Dr. Micro Tool putty, but I don’t know what countries it is available in.
The best purpose model putty hands down is squadron green putty!
The worst thin is its no longer available here in Australia, have to get it off the net, any shop with mail order will help you out.
Be careful with some Auto body repair Putty (Known as Bog!!) It can melt styrene!
