Best material for groundwork?
Hi all,
New to FSM’s forum and modeling after a 9 year absence due to school, work and kids. That said, what motivated me to jump back in was I found out that the 2006 IPMS Nationals will be in my hometown of KC this year! Whoo-hoo! So, I busted out all my hobby stuff after building a custom made hobby room.
I will apologize in advance for some potentially basic questions but since a lot has changed over the last decade and I would like to pick the brains of this group for some help. Here are the questions.
I am building an east front diorama and starting to work on the groundwork after finishing up the tanks and the figures.
I was wondering what everyone thinks is the best off the sheft groundwork material these days? I used to use Celluclay but never seemed to get the water content right and the groundwork would inevitably shrink slightly.
What is the process for putting this material down?
What is the best products for painting this groundwork?
Where can these materials be bought?
Many thanks,
Marty
Hi Marty and welcome back to the hobby,yes alot has changed since even when I first started back in the 80s(been back now for 3or4 yrs),aftermarket stuff everywhere you look,not too much in the way of scratchbuilding nowadays and no Monogram armour anymore,it`s a different world now,lol!
That is exactly the very reason that I`m not using Celluclay in this second kick at the can here,I now use natural dirts,sands,Life-like and Seanic grasses,roots for trees,tile grout in natural colours,real pebbles etc. These are all applied straight to the base dry and sealed with whiteglue and water mix.Expirementing is the best way to develope a system of getting the right mix of groundcover,then comes the rubble. Crushed chaulk,broken plaster,broken plantpots,cat litter and real crushed brick are some of the things I use for rubble.[:)]
I use plumbers putty - 2 part epoxy paste, it dries really hard, has good working time and cheap, you can also apply some ground work - like trees right into it if your layer is thick, and that will hold it in place.
Welcome back!
I’m still a fan of Celluclay. I mix in some white glue, earth tone acrylic paint, railraod ballast for texture and just enough water to get this to the texture of thick oatmeal. Before applying this to a base, I drill a number of 1/8 inch holes to give the mixture more bite. It’s pre-painted so tyou’re ready to add a bit of highlighting. I’ll then use Woodland Scenics fine turf, bushes and long grass, Armand Bayardi trees and stumps, (Pressed into the moist celluclay to get a better feel), 3 Guyz “Just Grass,” various Hudson & Allen forest debris, and dried flowers from the local Michael’s or AC Moore.
Here’s a link to my gallery at Armorama. Have a look at the results.
http://photos.kitmaker.net/showgallery.php?cat=500&ppuser=591
