My attempts to paint the hull of my USS Arizona model have been nothing short of disastrous. The only way I can see to repair the damage is to strip the hull down to bare plastic again and start over. I’ve used Tamiya white primer, Model Master Acryl and enamel to paint it. Is there something that will strip them all without damaging the plastic or the glue?
Getting very, very frustrated with my lack of painting skills. Something I used to be GOOD at, dang it! [bnghead] [bnghead] [bnghead] [bnghead] [bnghead] [bnghead] [bnghead] [bnghead] [bnghead] [bnghead] [bnghead] [bnghead] [bnghead] [bnghead] [bnghead] [bnghead] [bnghead] [bnghead] [bnghead]
Ammonia (like Windex) will strip acrylics fast. Brake fluid will remove enamels. ELO (Easy Lift-Off) by Floquil I think, also strips paint safely from plastic. ELO also works on the clear undercoat that chrome plated parts are treated with. A buddy claimed that ELO is just brake fluid, but I have not been able to confirm. You might need to try a combination of cleaners to get all the paint off. Remember to test on an inconspicuous area first, like the inside of the hull, to avoid potential grief. HTH.
I found an article on the IPMS website that said oven cleaner will do the trick on all the paints. We just happen to have a can of the brand mentioned so I’ll give that a try. Need to find a container I can put the hull in while the stuff works first. And a pair of rubber gloves that fit my paws.
Tamiya’s primers are lacquer based and aren’t the same animal as the acrylic paints.
The bottled primers (Liquid Surface Primer) can be cleaned up with denatured alcohol. I haven’t used the canned primers so I don’t know what would move those.
