I have completed my airbrush set up. It is an Aztec external mix brush, small air compressor and Badger pressure regulator up to 60 psi. I would like to know what would be the best work area setup with no spray booth. Any info will help.
I also don’t have a spray booth. The thing that best works for me is a good ceiling fan, my work area is open, and I spray next to a window. And always wear a breathing mask…
Here’s a quick inexpensive option if you don’t have a spray booth. Get a box fan and furnace filter. Tape the furnace filter to the back of the fan. Put the fan in a window so that the air is blowing outside. Spray your model in front of the fan. It’s not as effective as a spray booth, but it’s better than nothing.
