beatiful 1/24 brass Pak 40
Fellas,
I’m not usually a big fan of including links to other sites, but I thought I would share some absolutely beautiful scratch building work on display on the Armorama site.
It’s a Pak 40 that is just brilliant. It doesn’t fire, but you can imagine that with small enough shells and charge that it could. This is the final set of build pictures, but if you search you can find the other parts of the build log.
http://www.armorama.com/modules.php?op=modload&name=SquawkBox&file=index&req=modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=115265&page=1#955191
Wow, thx Novice. That gun is just awesome.
…Guy
Real neat. Thanks for sharing [8D]
Yes it is stunning.
wow, just WOW, I think I am going to change hobbies [BH][swg]
Oh my!
I’d never paint it! Leave it as it is- a work of art.
Thanks for sharing.
Unbelieveable craftsmanship. If you click on his ‘Profile’ and then ‘Threads Started’ there are 4 or 5 related posts with more pictures.
WOW awsome.
Hi all!
My name is Stefano and I’m the modeller of this gun.
I casually found this post searching in the web for my nickname.
It’s in 1/16 scale and non in 1/24, total lenght about 38cm.
In the following photos the complete and painted model, I hope you like it!
Bye, Stefano aka stebi51 from Rome, Italy.[:)]
If you like, can see all work in progress from the beginning here http://www.modellismopiu.net/m+gallerie/main.php?g2_itemId=83349
[View:/themes/fsm/utility/:550:0]
~STEFANO~ This is absolutely Top-Stuff! It really doesn’t get any better than this fieldgun of yours. It appears really flawless, and I’m am very interested to follow the link back and read the entire build–that said–I would urge you to return here and post your fine work on FSM Forums again—we need your kind of talent here !
Awesome work!
stebi51 Can’t hang that on the wall…'cause its off the hook! [:D[ Woah! Cool Pac 40 anti-tank weapon.
