I finally finished the saucer section! I’m busy gluing a bunch of cooling fins onto my warp nacelle master. I thought I’d take a sec to show you a couple pics of the finished saucer section master less it’s sealer coat.
Well back to those pesky fins. This is going to make me cross eyed![:p]
Hee Hee, Thanks Matt! I just sprayed the sealer coat on my warp nacelle master and it looks like I can call that little hurdle done too. Let’s see, just warp nacelle pylons and bussard collectors to go. [^][:D]
I’m starting on the four warp nacelle pylons and I would like to ask a question.
As a potential builder would you like the pylons as four seperate pieces, attached to the engneering hull, or attached to the nacelles. I’m leaning toward four seperate pieces with locating holes in the engineering hull and pins on the end of the pylons. Because they are so thin, I was also thinking of casting those parts with a section of brass tube placed in the mold before adding the resin. What do you think?
So I’m thinking that rather than casting weaker resin pylons, why not just include lengths of brass stock that the builder can cut to length? If there’s any little doodads, those can be separate resin pieces or scratchbuilt by the builder.
Woody have you ever thought to cast the thinner pieces in white metal since white metal is structurally more stable than Resin and it uses the same type of molding material that resin does.
That’s not a bad idea. I’ve thought about buying the equipment to melt and pour white metal. I’ll more than likely be trying that out somewhere down the road.
