my go to detail brush remains Badger’s 100 with its .25 fine nozzle/needle setup. The 100 always sprays softly and with an addition of a high roller trigger, I can control camo patterns better than my other guns.
My 100 is 25 yrs old. Love these old Badgers, and their excellent customer service as well.
I’ve got to throw in with you. I have a Badger 100 with a side feed cup that I got in 1986. It’s like a little jewel and is perfect for small batch painting and fine details. I also have a Badger 150 bottom feeder and a Badger 200g (gravity feed). Both are 30-35 years old and still work perfectly.
I have a Badger 105 Patriot with a G-cup. I have three needle-nozzle sets. I will upgrade at some point when I become better at the craft, but it works well for me now.
I have a Badger 105 Patriot also, but had to install the detail kit (.3mm) to get it to spray the way I wanted without that quick transition from fine to wide in the .5mm fine installation. Still prefer the 100 though for fine work.
I have had a 150 for about 25 years and a 100 for 5. Love them both, i keep the 100 for close up fine work as the top cup doesn’t get in the way and the 150 i have the medium set up for more general use.
I have never had to use their customer service, but was thinking of sending of the 150 for a check up.
While I do have a DA Badger 150, the 100 is still my goto brush unless I am doing camouflage or shading. I am on my second 100, replacing my first one after forty years.
Only thing I don’t like about new one is bottle adapter is press fit, and it occasionally falls off. I have tried everything I can think of to get a tighter fit, to no avail. Not a big problem but it can create a mess when it falls off.
I’ve considered a 100 over the years but just keep using the old version 200 often with side cup. It uses the same tips and needles. I painted a 1/25 scale engine with that yesterday and an interior today, both with .25 setup and side cup. It’s over 40 years old and that .25 is original.
