This is Hase’s Kate 1/48. This is for a GB placing emphasis on the weathering these planes displayed. Using the salt chip method and scraping/sanding off the top coat for the chipping effect. The NMF underneath is MM metalizer which I do not recommend for a NMF undercoat. Even if you buff and polish, it still leaves behind a fine residue that paint will NOT adhere to. I found this out the hard way. I will stick to Alclad from here on out! Anyway, comments and crit welcomed…
Wulf you do realise that with Metalizer you need the sealer so that the metalizer will not interfere with your top coats paint adhesion. And I would actually recomend Model Masters rattlecan Metallic Silver for a better NMF.
Looks great wulf, The wing meatballs are very well done (fade) as is the paint chipping on the cowling. I have a pic of about a half a dozen japanese aircraft on the deck of a carrier coming over to the us and not one of them has even a decent paint job. They could build one nice fighter but getting the paint to stick was a different story. I think you caught that look pretty good.
