Here is my question. I use a lot of acrylic paints with my Aztek airbrush (the cheap
version of the fancy one). I use the black and white acrylic nozzles. After 4-6 models, they clog. I’ve used both alcohol and water to clean them, but internally,
they get clogged, and I’m running to the hobby shop.
Does anyone have a good way to clean these nozzles other than blowing large
amounts of alcohol or water through them? Can they be disassembled?[?]
Man! I’ve painted 10 models so far with my Aztec, the original nozzles, and enamel paints and the spray patterns are just as good as they were brand new. I know the nozzles are pretty inexpensive, but every 6 models! That just doesn’t seem right at all. Sorry I can’t help out on the Acrylics.
First, the tip assembly can be disassembled, and I guess if it is a last ditch effort it’s ok, but I don’t recommend doing it regularly… maybe like some of the people here talk about for the ‘other’ airbrushes… about every 4th or 5th time you could clean it like that… reason is, it’s not really a needle you’re dealing with on the interior, it’s a piece of plastic and easy to mar or bend the tip on (voice of experience)
When I had an aztek I would take off the paint jar, clean it well… replace it with about 1/2oz. of thinner in it (don’t use laquer thinner as the aztek is all plastic inside) and blow it out. I would then check the tip assembly and see if it was relatively clean. If the major portion of paint was gone I would then set it inside the jar, and just cover it with clean thinner. I let it sit at least overnight, occassionaly, especially with enamels I would go and swirl the jar to make sure the dissolving paint was carried away from the tip and undissolved paint was exposed then.
After all THAT… when I took the nozzle out of the jar I would wash it in soapy water then rinse with clear water… (now yall know why I didnt like to spray enamels at first)
When I was all done I would blow out the tip and maybe run a smidge of thinner through to clear any residual out…
I usually had no problem like this… only once did I have to buy a replacement head… they’re not too expensive but enough so I wouldn’t want to do it as regularly as you…
At 8 bucks a tip, 7 or 8 tips worth could get you a complete Badger or Paasche set from dixieart.com, 9 tips would buy you one from Michaels with the 50% coupon in the sunday paper… ($76 bucks at Michaels for the 175 set, about $65 on dixie art for the same set, comparable pricing on the Badger 155 and Paasche VL sets for both places.) just something to think about… if you did get one of the two I think you would be pleasantly surprised. I used my aztek and it performed decent for what I wanted it for… now with the Badger 175 it is a whole different world.
Not to push you towards one airbrush type or another, but I think a metal brush would make you happy… no more plastic nozzle tips etc… easier to clean being metal too… shoot some laquer thinner through it and it’s clean as a whistle!
Thanks you all for the info. I did take apart the two offending nozzles and they are sitting in solvent alcohol. I figured, if they don’t work, don’t worry. You should see the junk coming out of them.
I’ve never had to buy a replacement nozzle. I take the nozzles apart all the time. I use Windex to clean the airbrush and bottles after using acrylic. You can also soak the nozzles in lacquer thinner with no ill effect on them.
I have an Aztek and do something similar to what Tailspinturtle does; after painting, flush system with thinner or windex, and then flush again with water. I take the nozzle apart and ensure no paint is left in there. I only had to buy one replacement nozzle and that was due to not taking apart the nozzle to clean it…paint dried up and the spring was solid. Since then, I haven’t had to buy any new replacements and I’ve had Azteks for a few years now.
not according to tailspinturtle, he has one and posted it above… I dunno, I would try both the red tips I sent you with the airbrush, one works, the other I am not sure… if one doesn’t work try dipping it in laquer thinner and see what happens… if both work just learn to use enamel [:-^][(-D]…
oh… and you CAN soak the brush parts in enamel thinner… so don’t worry… email me once you get the airbrush and I will tell you some more about how to use it… it’s a little different than the airbrushes you see most of the postings about on here… not much but a little…
oh yeah, when you get the airbrush attached to the end of the air hose is a silver connector, with a black connecter attached to it… the black connector is for a compressor, just unscrew it and the silver one should spin right on the top of your air can…
I only ever used one nozzle on my Aztek, the brown one, and did some awesome paint jobs with it.
It died when I ran Alclad through her, the ‘O’ ring around the needle actuator perished and leaked paint into the body.
Had it fixed, and stuck her on the shelf.
Hmm! I use lots of Alclad without any problems with my Aztec. I always use their Alclad airbrush cleaner though, as Alclad’s are a water-based laquer, which is a bit unusual. I actually wrote to them at one point asking about alternatives (their cleaners are hard to find here in Oz) & they said Acetone should be ok. It’s also good to pull the Aztec tips apart & clean them up pretty regularly, this seems to make all the difference. I soak them in acetone for 20’ or so & then wipe them down.
Hi all
I was going to buy an Aztec A470 from Micro-mark but after reading some of the above posts, I’m not so sure. What would you suggest in its place. It seems to work well if it is properly cleaned and serviced, that goes for most things. Is there any body who would recommend the aztec?
regards Neil
There are a few people who have had good luck with the Azteks, but if you search this area of the forum for the word “Aztek” you’ll find plenty of posts pertaining to them. Most are negative, a few are positive. Personally I prefer Badgers.
