I wanted to share my experience with Aztek AB nozzles.
I was painting with very thinned MM acrylics and clogged three of my nozzles. I could not get them unclogged using my normal cleaning techniques - which had always worked in the past. I remembered the post of a few months ago (in French) describing how to disassemble the Ab and nozzles, so I tired it. The center pin assembly of the nozzles pulled right out and exposed the clogged interior. A little Windex later and I was back in business.
The mfr’s warning says not to do this, but it saved me junking about $35 of equipment and becoming an Aztek hater! I never had a real problem with the AB or nozzles before. I pass this along to other Aztek users to deal with the problems they’ve had with the AB.
You’re right about that… They say not to do it, but on my Aztek 4704 I usually disassembled it after each session before storing it again. I just put the entire disassembled nozzle assembly in a small 1/2 oz glass jar with acrylic thinner and then let it sit for a few minutes. After that it was usually pretty clean. Still didn’t dissuade me from buying a Badger Crescendo 175 though…
Thanks for the tip. I have the top of the line Aztec but have not run into a problem yet, but I have not sprayed Acrylics with it either. No problem with solvent based paints as yet. I do like the Aztec though.
Hi,
I also used the previous article that Steve refers to and finally got my nozzles completely clean. Just one word of warning though, if your nozzle is really clogged and the centre ‘pin’ is reluctant to come out, watch out for the spring pinging off across the room. I disassembled 2 nozzles this way without a problem, but on the third, the spring launched and was never seen again.
Since using this technique my nozzles never get so dirty and I strip clean them after every session. I leave them assembled in a jar of thinner when not in use. I use acrylics 99% of the time.
I found I had to do the same thing when I started using Acrylics. It was giving me fits. Pulling the nozzle apart worked perfect.
I’d been using my Paasche VL and my Aztek 370 equally, but since I switched to acrylics, the Paasche has been giving me fits- tip dry like mad. The Aztek hasn’t had the problem. I did find that the Paasche handled Tamiya well, so I ordered some more of that. But the Polly S- while it goes down nice- just dries right up.
Ive tried spraying MM flat acrylics for the first time and have had a problem with the paint drying and clogging the head/needle assembly on my Aztec A470 and also on my Badger 150 . Never had this much trouble spraying Tamiya flat acrylics , although it also would clog the head eventually . It seems that MM acrylic has a more coarse pigment than Tamiya .
I use lacquere thinner to clean my Aztec and so far (knock on wood ) havent had to disassemble the head assembly.
Ive unclogged my airbrush while spraying MM flat acrlics by dripping a few drops of lacquer thinner into the head assembly ( while airbrush is still assembled and hooked up to air hose )then blowing air only through it . Seems to clean it out for awhile but eventually it will clog the head / needle assembly again . This process slows up the paint job quite a bit .
Buy the way i’m spraying camoflauge with a soft over spray edge but get to much overspray with the MM flat acrylic . My results were much more satisfying with Tamiya flat acrylics .
I’m about ready to give up on the MM flat acrylics .
I’m a very new airbrush user, so I thought it might just be me - but I have had a similar experience with MM flat acrylic paint. I have a Paasche VLS airbrush and find that the Tamiya flat acrylic paint flows flows better, clogs less often and gives better results. But I still don’t rule out the fact that I am a novice and it could be me that’s doing something wrong to cause this. I also notice that the MM paint has a very clear phase separation and requires a lot more mixing to get it homogenized than the Tamiya. It’s possible that I just didn’t spend enough time mixing.
Larry hi . Ive been airbruhing for a few years and have primarily used MM enamels with few problems . However my bad experience with MM acrylics has me stumped . I dont know if there is a acrylic thinner by MM but i have not found it locally , maybe using it could help .Have you used it ? I did have Tamiya’s acrylic thinner and used it ,which did slow the clogging problem some . I used it along with a acrylic paint floating medium which retards the drying time . Ive tried using isopropyl alcohol as a thinner with no success , it causes the paint to clog even faster in my experience .
So far my besrt results airbrushing MM flat acrylics are :
Thanks Shell - I was using water/isopropyl solution for the MM acrylics, which is what the fellow at the hobby shop suggested. I may try some other solvents to blend with the water to experiment with. Has anyone tried using white wine/water mixture? The ethyl alcohol in the wine maybe could produce a different characteristic than the isopropyl. I probably won’t pursue alternatives too vigorously since I’m fairly content using the Tamiya acrylics.
Zoloft seems to be working OK for me. Helped me break out of the deep depression I was in for 2 years. My new modeling hobby (just started a couple months ago) is also adding some zip to my life as well.
I use Vallejo Acrylics model air line through my 470 I started getting cloged tips also and finally took them apart like it has been discussed and have had zero problems yet i use both alcohol and windex to clean up everything after use and then i continue to soak the tips in the windex till the next use and leave a little alchol in the paint cup of the ab to keep it alrdy to go
I’ve used MM acryl in the past and now I am an avid believer in Vallejo… With MM use Tamiya acrylic thinner, maybe add some retarder to it (you can get it in the paint section at Hobby Lobby or Michaels)
With Vallejo, using their own brand of thinner seems to do the trick although the retarder can help if you still have problems…
Thanks Tho and k , sounds like im using the same thinner and pressure , only my reults w/MM are different . I’m gong to look for MM acrylic thinner ,if there is such a thinner , and if so use it . If that dont solve my clogging prob then its time to switch paint brands .
I use Tamiya Acrylic thinner which as a retarder built in for both Tamiya & MM paints. Usually its not a problem on my 470. I also clean by the usual spraying until clear, then pull the nozzle out and dump in a small container of windex. Sometimes I even just leave the nozzle in there until the next time I need it with no problems (I’m tallking weeks of months!). No on mentioned it, but Aztek makes 2 nozzles especially for Acrylic, the others are meant for enamel. I’ve noticed the acrylic nozzels do not clog as easily.
There are two types of acrylic thinner made by Testors. The first is Model Master Acryl Thinner. The second is Model Master Acryl Detail and Fine Line Thinner. This first is used for general thinning and cleaning. The second is more aggresive and is used for fine line detailing. Testors states that all of their Model Master Acryl paints (excluding the skin tones) are designed for airbrushing straight from the jar. Unless, of course, you’re doing detail work. There is also Model Master Dried Acryl Cleaner which is great for final cleanup work. If you’re having excessive tip-dry, try reducing you air pressure. Before I begin airbrushing with Acryl paints, I kept a Q-Tip moisten with Acryl Cleaner near by. If the tip starts to dry, I rub the tip gently with the Q-Tip, shoot a blast of air into rag, and then go back to painting.
Like many of you, I use a variety of paints through the Aztek. I read all the posts here, and you’ve all helped with your ideas and suggestions.
One other thing that seems to help is to put the nozzles in one of those cheapo WallyWorld (Wal Mart) ultrasonic jewelry cleaners. Don’t do it with a volatile solvent since the solution can heat up, but with isopropyl or Windex it shouldn’t be a problem. I usually put water in the tank, and then put a smaller jar with the nozzles and cleaner in it, kinda like a double boiler.
A few minutes seems to get those tougher clumps out.
