Hi all
I have just managed to buy a hardly used second hand A470 for a good price, but I have a question for any other A470 users.
The trigger on mine is quite loose. I’m sure it won’t affect performance but does anyone else have a loose trrigger?
Thanks
The A470 is the only one i’ve ever used, and just play with the little silver dial on the back. It might be set to one extreme. Remember, its usually the user, not the tool. Dont take that the wrong way.
LEGENDS!
Well that’s what I get for asking before I check out the tool!
In my defence I have just received it at work so have not had time to watch the video.
Anyway thanks a lot Blakjak!!
Another tip about the Aztek airbrush. If possible, use a compressor that has a storage air tank. The smaller air compressors that deliver air in rapid pulses wear down the Aztek tips quickly while the smooth flow from an air tank that the compresser recharges allows the tips to last mmuuchhh longer.
I haven’t had any problems with mine…
Yet…
Besides the tips getting plugged, but that is solved quite easy, by soaking them in some thinner.
My trggier is not real loose, but there is a little bit of play, it works fine. The air compressor is the way to go.
