Aztec model AC500..Help!
Well I got this compressor for free from a friend of mine. The catch,I have to
figure out why its not working!
He only used it TWICE and being the slacker that he is,didn’t make use of the warrenty while he could [xx(]
The problem:
The compressor appears to be working properly but its not filling the tank. there is air comming from the output hose but theres maybe 1-2 psi at most. If anyone knows how to fix this or even where I could send it to be fixed you’ll have my eternal gratitude. Thanx
Don’t know anything at all about that compressor, but if you need to send it somewhere to get it fixed that would probably be Testors / Aztek. They have customer support information on their web site at this page:
http://www.testors.com/help/help_desk.asp
Shrugger,
I think there is a problem in the regulator. The output line is open all the time and not allowing the air in the tank to build up to it`s rated pressure.
Dave
Thanks, mail to Testors is sent.
I took the regulator off the output,so its straight out the open/close valve
Wich is working fine.
Since I havn’t been able to locate any leaks I’m beginning to think the piston
thing is defective, letting the air go back out instead of pushing it into the tank
Wow! I fixed it!
Seems the valve in the head somehow got cocked sideways leaving it open
Now I’ve got a $300 compressor that only cost me a few hours of my time
I think I’ll tell him it cost me a fortune so he doesn’t go around kicking himself [:-^]
Hi Shrugger, I have the same problem with my compressor (no leaks to be found, motor works fine, wont hold pressure beyond 1 or 2 psi), and I’ve had it apart a few times now but cant find the problem. You say the valve in the head was out of position. By valve, do you mean the small brass strip on the head of the piston that covers the inlet hole? I dont see any other things that would be considered a valve and that strip of metal seems to be in its proper place, could you help me out? I really would like to get this fixed. Hm. maybe mine has a different problem.
Ha! success at last. Your post kept bouncing around in my head and I opened up the head again, and noticed what you were talking about, and it’s such a measly simple little thing. very annoying. Here’s a write up with detail for the next guy this happens to.
do not disconnect any hoses while doing this, and make sure it’s unplugged!
open the head of the compressor (the red disc with six screws holding it to the cylinder)
be careful to not unseat the main gasket attached to the actual piston. doing so can cause the piston to come out of allignment. You will be working on the part that is now connected only by a hose, and not on any part of the main compressor.
On the underside of that red head you just took off there should be a silver portion with two screws holding it in place. there is a hole on one side that matches up with the piston, there should be a rubber stopper inside that hole that should be flush with the metal when the compressor is off. If you can see into the head through that hole, then it has become stuck and is not sealilng. The inside of this mechanism is just a spring and a rubber stopper. It is held in place by six metal posts, which catch the spring and bind it up, preventing it from closing. Had the makers put in a proper cylinder for it to travel in, it would never malfunction, but the posts are just perfect for catching the spring.
To free it up just stick the end of a toothpic, or the blunt end of a paint brush into the hole against the rubber stopper and compress the spring a little. It should pop free and close, flush with the metal disc. If this does not do it, open the head carefully by removing the two screws holding it in place. The metal disc is hard to get out, I used some tweezers and pulled it out by the hold, do this carefully so you dont damage the disc or the head it sits into. Now open you should be able to put the spring and stopper back in place (spring against the top of the head, the rubber stopper facing down towards the floor). Now put it back together, careful to not over tighten any screws. before you put the head back on, check the stopper with that toothpick again to make sure it travels properly and seals up on the cylinder. Now put the head back on the compressor, again, make sure the main piston gasket is seated right. Tighten screws in alternating pattern to be sure the head sits down evenly without torqing.
It should work fine.
Such a simple thing. I can’t believe I missed it the first few times, I just assumed that the hole was meant to be open. Thanks shurgger for the help! Hope this write-up helps the rest of you guys!
Thanks for the tip! I followed the steps and my air compressor is now working. Once again thanks.
