hey everybody, i’m building a monogram B17 in 1/48th scale and im adding eduards photo etch parts inside (all sections) any suggestions about glue or anything else i want to get it right , i’ll add photos as i progress with the build any help will be greatly appreciated thanx, Dave[:D]
for PE I would use super glue. And accelerator if you have that stuff.
OWL
Flat PE on a flat surface…Future works well. For objects that have torsion or minimal mating surface such as handles I use thin CA. Good tweezers are a must!
I also use my own product for such applications. [whstl]
I prefer to use a gel-type super glue for attaching photo-etch parts.
Mark
thanx everybody, your help is greatly appreciated progress pics to follow soon!
Dave,
A file to remove those pesky nubs after you have removed the PE from the tree.
MOST importantly…Patience…to avoid[bnghead][cnsod][bnghead]
Good luck
I’ve been using Micro Mark Kristal Klear for flat to flat joins. If there is a small gluing service (handles attached to intrument panels) I drill a hole in the plastic part and insert the PE. If I have to attach something to a flat PE piece I drill though the flat PE placing it on a glass surface so it doesn’t bend. More work but less chance of knocking parts off.
