Which grey is it over flat white? I assume the flat white is on the bottom as well. It appears to me from photos that the grey portion is really miniscule, around the cockpit it seems. I love this scheme but have not done it yet. I have a dauntless from accurate I want to do it on.
The gray that you speak of is almost a dead match to gunship gray. It does happen to be on the tad lighter side though. So, just add a drop or two of white or light gray to it and good luck!
Ps I’m currently building the Dauntless right now; Follow those instuctions to the letter or else you’ll have an expensive plastic ball.
drew
You know, you are dead right. I took out my accurate avenger which is 1/3 assembled and put it right back in the box. Funny thing is, I have followed instructions and the dam thing still don’t fit together. I am so pissed off about it. I get so irritated, the more complicated interiors are, the less likely they are going to fit the fuselage halves together. There is a direct relationship, more stuff inside, wider the gap. Take it to the bank!!!
