This might be a bit hard to explain, but bear with me a moment. I am looking for people’s preferences on whether people build and assemble their tracks and leave them assembled (track glued to the wheels, drive sprocket, etc.) or leave them in seperate components prior to painting. If you do assemble them and leave them assembled, do you also leave them on the tank or remove the “assembly?” I am guessing that it also depends on the types of tracks (vinyle, link/lenght, individual track, plastic/metal… whatever). Also kind of looking for pros and cons of each.
The reason I am asking is that I currently paint individually and then assemble after the main body of the tank is close to finished (as far as the lower half goes)… but I also feel this is not the best way for me to do this. Some issues I run into are that I find it difficult to do without damaging some part of the weathering or having the track break at least once in a random point. I have a bit of a tremor (medical issue) so fine motor skills can be a bit difficult at times. I find this especially true when the tank drive sprocket is fixed and does not rotate making it next to impossible to feed the track back over everything and under the fender and everything else that gets in the way.
Lastly, what methods do people secure their road wheels and such to the model when they are forming the tracks around them? I tried using a small bit of Tamiya quick liquid cement (as I’ve found it doesn’t hold as well), not always, but I have had disasterous results when trying to remove them again.
I model mostly German and Russian WW2 armor so tips related to Tigers/Panthers, T-34’s, KV-1’s will probably be the most helpeful if they are not universal techniques.
