Artillery PE sets
Anyone know if there is a PE set and aftermarket barrel for the Italeri 1/35 105mm howitzer? How about the Tamiya 75mm Pak40? I have both kits, but am holding off building them until I complete the 1/35 ICM Russian BS-3 (excellent kit, BTW)
If there are barrels/PE sets available, who is the least expensive?
Thanks in advance for all the help.[:)]
Gip Winecoff
Yes, Eduard makes a PE set for the 105mm M101 howitzer. It is #35242. Go to http://www.eduard.cz and use their advanced search function to look for the other item.
Thanks, Rob!
Now, who sells them the cheapest?
Gip Winecoff
I’ve got a buddy who can special order them for you. He normally passes on his savings to the modeler:
http://home.comcast.net/~alpenflage-hobbies/alpenflage.htm
Or the old standards: http://www.squardon.com
or http://www.greatmodels.com
Wow…
Thanks again, Rob. I’ll try your friend first.
Thanks also for being right on top of my posts.
Gip Winecoff
