Hi all, I’ve begun my Arado ar234 build for the 1946 what if group build.
I’m building the Revell-Monogram 1/48 ProModeller version which I’m going to modify as a form of mistel carrier of a t.v. guided tactical nuclear unit as part of the what if portion of the build.
A simillar idea to the ar234/381 mistel configuration slung below but with a larger, but not as large as the, aircraft loaded on top as further below.
So it looks like I’m in for a bit of scratch building.
Starting off we have the box and its contents.
Next up I gave all the parts a wash with some warm water and dish detergent and a cool rinse.
Always be sure to feel around in the wash basin for any loose parts and pull the drain plug but leave it in to catch anything from going down the drain.
Like these two little fellas below. It’s not like they were going to go down the drain but even large parts can have delicate sprue attachments and fall off.
Then I let them dry overnight next to the open window.
Once they were dry I gave the cockpit parts a base coat of Tamiya XF-1 flat black thinned with X-20A thinner.
I built the spray booth out of some scrap and a brushless bathroom fan feeding into a coffee can filled with filters. I only spray acrylic these days and it has some really good airflow, you can’t even smell the paint at all.
It still needs a decent light installed.
Next up I’ll prime and assemble some other portions while the cockpit primr dries so I can get to work on that detail.
Such a massive ‘wall of glass’ means there are lots of fiddly bits that will need some accurate attention and will have to be one highest detailed cockpits I’ve ever built. I guess I’m a sucker for punishment.
-Colin.
