April Updates are posted
April Updates
I have several pics in this month’s update which I think are very awesome. At least for me. Continuing on with the drydock build I was able to make some molds for both the fronts and backs of the light panels. I also made a few test casts to see if they would turn out the way I wanted. I found a few things I wanted to improve on with both of the molds. I want to be able to add the lighting effects without having to add any extra parts or drill any additional holes. I’m really trying to think this build all the way through, guys. So I’ll take the extra time needed so if I every build additional drydocks I will have everything in place. I’ve been trying to learn from my past Drydock Build which took about a year and a half to build entirely from scratch. I really never dreamed I would build another dock much less a larger version of it. But I did learn a really valuable lesson from that experience and yes, “CASTING” is going to be the way to go for a highly detailed model like these.
In other areas I’ve also finished making the master for the underneath of the overhead modules. I was able to do a lot of kit bashing for the detailing work. I tried to follow the basic patterns on the original filming miniature as close as possible. I tried to find pieces that resembled what was on TMP Dock. I was able to make a single piece mold for this part. I then tried casting this piece and the results were fantastic. At this posting I was able to cast 14 of the panels for one of the Docks. As I brought out in my last month’s update I am casting all of the parts in Black resin. This will reduce light leaks as well as the need for spraying all of the parts Flat Black. I have several pics posted of these panels. Check them out.
Along with the bottom panels I have also finished the master for the side walls of the Modules and have begun work on the front right and front left pieces where the landing bays are. I should have these pieces completely detailed as well as molds for casting the pieces. So check out the new pics in the April Updates Page and let me know what you think. Next Month’s update should be awesome as well. See you then!
Happy modeling, Mark
Sorry I hit the wrong button. Go to this thread instead
ST:TMP Drydock - Larger scale - WIP
