Anyone own/use an Iwata Sprint Jet compressor? Thoughts?
Hey Mike,
Just to clarify (and not that it really applies for us in modeling) but my sprint jet says it’s rated all the way up to 100 + p.s.i. - and it sure feels like it too. The dial on the compressor seems to be pretty accurate. Now if the Createx is a 1/6 hp as opposed to the Sprint Jet’s paltry 1/8 I would expect it to be able to create even greature pressures.
Just what I’ve found on mine anyway.
Bri~
Brian,
I think that is a static load rating and it does not apply to real world use.
My 1/2 hp Jun-Air only goes up to 120 psi so I know that little Sprint Jet can’t put out that kind of pressure.
The numbers I quoted in the post above of 40 psi and 70 psi are continual use ratings. [;)]
yo mike, i thought the sprint jet had 1/4 hp i think , and the silent jet had 1/8’th. i remember clearly the silent has less hp’s.
The Sprint Jet is 1/8 hp: http://www.arttalk.com/iwata/compressors/sprint_jet_air_compressormainpage.htm
What is the “Silent Jet”? They don’t make one by that name.
You either mean the Smart Jet (also 1/8 hp) or you mean the Power Jet (1/6 hp).
my bad, i thought smart jet was a name [;)] hmmm. may just get a used fridge.
Gotcha Mike. It sure felt to me like it could have been 100 p.s.i. - shows what I know though! [D)]
[(-D] Bri~
I was wondering if anyone has been surprised by the contents of their Iwata compressor? I recently purchased a sprint, but on opening the box discovered an engine with sprint on it but an air-hose set up which seemed to be more like that on the smart jet (moisture trap not connected directly to the main body but linked via a hose). Dont suppose this really matters?
Same opinion w/ jfrejo. As I know sparmax made many brands include iwata. Same spec only different brand (iwata has higher brand image-also higher price as well). I own compressor twin piston product made by sparmax but different name/decals & paint color only. Consider to compare all spec you need at www.sparmax.com.tw (yes… it is made in china-taiwan)
For pulsation matter (eventhough couldn’t handle on/off frequency cos automatic switch), I use 2 moisture trap regulator w/ gauge, one attached direct to compressor firm with 30 psi setting , another one set to my bench, base on my experience, I could set any pressure at whatever I need even below 5 psi without no pulsation anymore.
I have the Sprint Jet but have had condensation shoot out of my Iwata ABs before (on cloudy or rainy days). had to dish out another $20 to buy the water trap that fits on the AB itself. other than that I like the compressor, quieter than the cheap Sears compressor I had before, but still not as quiet as I would like.
