I’m talking about the powdery, rough paint surface effect I get sometimes at the wing roots of my aircraft. It just happened on my latest P51 project. Whats really annoying is I know it’s dry paint landing on the surface because of the the vortex type effect in these areas but sometimes it still happens despite my best efforts at preventing it. I usually try to paint these areas first and get in reasonably close and get the paint on so it’s just wet and then direct the rest of my spraying efforts away from those areas but sometimes it kind of just sneaks up on me and before I know it, [:0] there it is. My usual habit is to use Tamiya acrylics thinned 1:1 with Tamiya thinner at about 15 PSI, which works perfectly for eveything else I try to paint. I think somehow I have developed a bad technique in the way I am handling these areas but I’m struggling to figure it out and I just can’t see where I’m going wrong. I think I’ll try gently sanding the affected area and respraying, rather than stripping the entire model, as I was going to use an expensive set of decals on this build and now I can’t justify using them unless I can fix this problem. Guys, any comments would be appreciated.
Cheers…Snowy [V]
