Answer - Trivia Series #11, Question #1
The correct answer is the Fouga Magister. In 1948, Fouga designed a jet-powered primary trainer called CM.130 for the French Air Force (Armée de l’Air, AdA) to replace piston-engined Morane-Saulnier MS.475 aircraft. When AdA found the aircraft lacking in power from the two Turbomeca Palas turbojets, Fouga enlarged the basic design and used the more powerful Turbomeca Maraboré engine. The distinctive V-tail of the new CM.170 Magister originated on the CM.8 glider Fouga was using to experiment with jet engines. In December 1950, AdA ordered three prototypes, with the first aircraft flying on 23 July 1952. A pre-production
batch of ten were ordered in June 1953 followed by the first production order for 95 aircraft on 13 January 1954. Fouga built a new assembly plant at Toulouse-Blagnac to produce the aircraft. The aircraft entered service with AdA in 1956.
The correct answer was submitted by skybolt2003, intruder38, wayne baker, jeaton, Ashley Messenger and Viper has the Lead. Question #2 will post shortly and thanks to all who participate!
Brian [C):-)]
