AMX-30 Upgarde kit.
Any body know where to get an up-grade for this kit? Everywhere I have looked is out of stock or the kit is discontinued? Which is it? I need one for a desert storm Dio.
I’m Confused, do you have the kit and looking for the conversion, or are you looking for both? What’s out of stock?
I have the kit, I am looking for the AM, to make a desert strom dio.
To be honest, I didn’t know they used these in Desert Storm! However, I hope this helps?!?
at Greatmodels.com
EDU35221
Seems to be the only PE set I’ve seen on there for the AMX HTH
There’s also a Mine Roller kit for it too!
DES35038
Check Blast Models. If it is a French subject, they usually have a few items for it.
Azimut makes a resin/PE Desert Storm update to make the AMX-30 B2. It includes new smoke grenade launchers, 5 gallon cans, stowage boxes, new coax barrel, sand shields and other resin items. The PE fret has mesh grills for the muffler covers and the circular air intake on the back deck (I seem to have misplaced my PE set).
I think the stock number is 35.129
Here’s alink to the set I have:
http://www.phpshopxml.com/azimut.shop/CID/3325912674bce5ae24dc45425402ef00/function/itemPageDisplay/shopItemCode/AZI35129
That was the kit I was looking for! Thank you! I also found the AML-90 I have been looking for to make an Eland-90. Also the French and Saudi’s used the AMX-30B2 in Desert storm. I have been trying to find Azimut products for along time. Once again Thank You!
