Gents;
I came into possession of a 1/35 M1A1 tank kit which was about 1/2 completed. The work already done is not bad and I hope to continue but I would like to build it as a Marine M1 serving in Iraq. Where do I start?? Who has good info on Marine tanks in Iraq??? As stated it is an AMT kit. the last AMT kit I built was a klingon battlecruiser from the 70’s How do they compare today???
all the best,
Dan [8D]
This kit is one of the poorest Abrams kits produced. While the basic kit was fairly accurate (but crude) as an M1, Esci/AMT/Ertl skimped when they produced the “M1A1”. They basically switched a few parts between the M1 and M1A1.
This leads to several problems:
- The turret is too small (frontal armor was increased)
- The turret bustle rack was incorrectly made. The actual bustle rack goes straight back and does not cant inwards.
- They made no adjustments to the lower hull. They failed to add the NBC over pressurization system in place of the left sponson box.
- The rear engine grill was crudely molded.
- The center guides are molded in the wrong spot. They should be between two adjacent track blocks and not centered on a single block.
This is all I can think about off of the top of my head. When they were released in the late 1980s, the only other Abrams kit in 1/35 scale was the original Tamiya M1. This kit was the first one to offer the new style turret blast panels, 120mm gun, and man hole cover.
As a model, it is not too bad. It builds OK and looks like an Abrams when completed. If you want to build even a semi-accurate USMC Abrams serving in Iraq, I’d suggest finding another kit such as the new (expensive) Tamiya M1A2/A1 and the DML USMC OIF M1A1.
Main difference visually between an Army M1A1 and a Marine M1A1 is that the marines use different smoke launchers. They are 8 individual tubes on each side as opposed to the army six launcer pack. Secondly, the Marines use a Missle Countermeasure Device (MCD) on the hellhole cover on the front left of the turret. It is a box that sits on top of the plate that covers the hellhole. These can both be seen in the above pictures and below.
