What you need is “Filler-Primer” or “Spray-Filler” - basically a thick paint in a spray can, that can fill the imperfecions in the surface. Sand the surface smooth after it dries throughly. Motip makes one that I can recommend. Good luck with your build and have a nice day
There is a big block of forums labeled Feedback, Help and Testing. In that block is a forum called Technical Assistance. Posting of pictures has been a frequent thread in that forum. Look at ones that already exist. If no help there, then start a new thread by asking the question there.
What I do there is this . I spray a cleaned and prepped hood with Krylon brand primer .Then sand it from front to back , till under running water it’s smooth and glossy without those " Ghost " marks .Then paint in a color of your choice ! T.B.
If primer will not fill the indentations then use automotive spot putty like bondo brand or 3M acrylic spot putty. The Squadron green filler putty can also work. I like to thin it a little with lacquer thinner. Use lacquer thinner made for models, not real automotive or household lacquer thinner . Sand the putty with 600 or 800 grit wet/dry sandpaper with water (wet).
Also note that the 67 Impala SS could come with a 427 CID big block and there were a few special colors applicable to the SS Impala 427. You could do a special SS Impala for a special little lady!!!
Yeah this one is supposed to be the 427. She fell in love with the Impalla from a TV show. That one is a 4 door with a 500 engine in it. The interior is black and tan (camel?). The interior doors, ceiling, dash and rug are all tan. The seats are black, oh and it’s a bench seat and it’s an automatic.
The AMT model is a 2 door and buckets and a 4 speed. So I decided to do a hybrid, incorporating items from the TV car into the model. I am also taking the doors and the trunk off so I can make them open and close. The trunk area I’m actually planning on using as a place for a circuit board and LEDs, micro switches and batteries for the lights. I am going to light the interior, all four headlights and the turn signals.
For everything that opens I am planning on installing mini rare earth magnets to hold stuff closed. If I can figure out an easy way to do it I would love to have the interior lights come on when the doors open.
From working on guitars I have sand paper from 400 to 12000 grit so I’m hoping I can get that mirror like finish.
I’m planning on using real metal for the chrome trim. I have already purchased an Impalla photoetch kit, an aluminium distributor with wires kit, a high detail guage radio and fan control kit, and a few other little things to perk it up.
