Here ya go Mike … more ammo for not cleaning your airbrush every time it’s used (as I tend to do[8D]).
You know the trigger spring in the Omni series? Those little suckers will bounce a ton when you drop them on a concrete floor. I picked up the needle chuck to put a little lube on it and never thought about the spring until I felt it hit me on the ankle. Took me half an hour to find the thing.
Yeah, tell me about it! Painting camo and the only store in town that might have them closed today and tomorrow! I was fixing to start hunting for the old-style ballpoint pens with the springs in them. Not sure if it would have worked, but not having a spring sure wouldn’t have.
Which spring are you talking about?
Do you mean the one in the rear assembly or the one in the air valve?
I am trying to visualze how they fell out? [%-)]
It fits over the “Needle Tube” and I forgot about it being there when I picked up the needle tube.
It didn’t fall out, I took it out. When I thoroughly clean my airbrush all of the guts come out. I like to put a little needle lube on the pivot points and the lever that leans against the trigger.
Like I told Chris, I was fixing to start scrounging an old ball point pen with a spring in it [:)]
I am WAY to hard headed to learn a lesson that easily. After all, I found it so the lesson was immediately forgotten[8D]. Besides, if it was that easy my basement wouldn’t have tiny little model parts scattered all over it. I keep holding them with tweezers, knowing full well that the spring action of a pair of tweezers can launch them into the next county.
