Anybody tried Aleene’s Clear Gel Tacky Glue for attaching canopies?
I’ve been using Micro Kristal Klear, which has generally worked well for me, but the bottle I bought back in February has gotten noticeably thicker, to the point where it’s becoming difficult to work with.
Aleene’s Clear Gel Tacky Glue was recommended to me as a possible alternative. It’s considerably less expensive, and apparently dries crystal clear.
Just wondering if anyone here has tried it for attaching clear parts, particularly aircraft canopies. I’d be interested to hear how it compares to Kristal Klear.
Sam you been here a long time, and have posted ALOT of material.
You should know by now that stuff is PVA White Glue, same stuff you can get at a schools art class etc etc haha.
Anyway you can use it, but its not a crystal clear cure. Stick with your original product, or if you want something soft on the plastic, this glue shouldnt eat it.
I also use it for windows and canopies. Dries clear, unlike Elmers. Cleans up with water in case you spill or over-apply it. Even can be used to fill small windows.
Thanks, everyone. I appreciate the feedback. That was exactly what I was looking for, and it sounds like it should work well for what I need. I’ll order some and give it a try.
I have obviously used generic PVA/white glue before, and I actually have a big bottle of it on my bench. My experience has been that it doesn’t dry truly clear — there’s always been a bit of a cloudy or yellowish cast to it. I use it when that doesn’t matter, but for something like an aircraft canopy where the glue may remain visible, I’d rather use something that cures genuinely clear.
If you want crystal clear results and the ability to instantly set the glue with no fogging whatsoever, I highly recommend trying UV curing resin. You can buy a basic kit that includes a small bottle of resin and a UV light for less than $15 (it will last for many dozens of models). Here’s an example:
The uncured resin is similar viscosity as styrene glue (it’s not watery). What I do is position the clear part were I want it, then carefully apply the UV resin in corners and edges, then hit the resin with the UV light. The resin completely cures in about 15-20 seconds. And it’s just as strong as PVA glue in my experience.
If you want more precise application than what the UV resin bottle tip can give you, then either use a toothpick or dispense some of the resin into a small black squeeze bottle with a needle applicator tip: here’s an example:
Thanks, Rob, you are exactly right that is a great glue alternative. I actually considered using UV resin to attach the canopy last night, but decided against it for one reason. If I accidentally get a little glue somewhere I don’t want it, I can easily clean up Micro Kristal Klear with water before it dries. In fact, that’s exactly what happened last night. I got a little smear where I didn’t want it, pulled the canopy back off, cleaned everything up with water, and started over.
That possibility made me a little nervous about using UV resin. I’m not sure how easily I could clean up a mistake, particularly somewhere it might be visible.
I do love UV resin, though! I used it last night to attach the taxi light lenses to the nose landing gear, and it was perfect for that application. I even have some UV resin dyes, almost like food coloring, that I mix in to make colored navigation light lenses. Green, blue, whatever color I need. It works terrific!
Have you ever had to clean up misplaced UV resin on a canopy before curing it?
Hi Sam. Sure, I have cleaned excess UV resin many times when installing clear parts. The resin remains liquid and able to be wiped away easily with a cotton swab moistened with alcohol before you use the curing light.
One of our members told us to paint the area black where the canopy sits. stops any mirroring from the canopy when looking at an angle. 40 years ago I used crystal clear, but for the last 35 years have been using ordinary PVC glue and have never had a problem.
Tony
Gold Reef Scale Modellers
Johannesburg
