alclad paints
Greetings, I’m about to run some al-clad paint thru my Badger 200 to finish off a Tornado but I’m worried about cleaning up afterwards. Can I use regular turps to get it all out of my brush or is there something special I’ll need to use ? I’ve just gotten a new head assembly for the brush & don’t want to screw it up ! Thanx ! !
You wil need lacquer thinner to clean alclad.
Acetone works best for cleanup of Alclad. You can use lacquer thinner too - that’s the only thing I use for airbrush cleanup.
Yes! No turps! Lacquer thinner only. Also, AlClad makes their own thinner/cleaner which might be the best thing to use.
I have always used turpentine for Alclad, even though it is a lacquer, and it has always seemed to work okay. In fact, I find Alclad easier to clean from my airbrush than any other paint I use- it doesn’t seem to stick to the parts of the brush or pickup tube like most paints do. I always try to clean it immediately after spraying- turpentine or mineral spirits might not work if it dries in the brush.
At work, if we use any metalicized paint (usually lacquer based), we use MEK to clean with. It’s about the only thing that clears the glitter outta the equipment. Having said that, I don’t know if Alclad has metal in it.
Reid
Alclad paints are awesome! They build up in thin layers even if you spray too much on your model (happened to me when first using them). I just use Revell’s “Aqua Color Clean” to clean my airbrush. I leke to use it, because I can clean my AB with it when using Gunze or Tamiya paints as well.
Clemens
Yeah, you’re going to love it. It’s the first paint I ever shot through my AB, and the paint I can expect the best results from my AB with. As others have said, Acetone or lacquer thinner is what I use.
Gene Beaird,
Pearland, Texas
Had a horrible first experience shooting Alclad, must try to get it right because it does look sweet… when done correctly.
