BK just mentioned that this stuff is made in the same facility as Vallejo…is AK Air just rebranded Vallejo Model Air??? Or is it the laquer based stuff? Nothing on the box or bottles says anything.
Gen 3 AK acrylic is supposed to be a whole new formula. I think you will find it tougher than VMA and that it behaves more like Tamiya acrylic than like VMA… I’m just going by reviews of the stuff, I need to get some and try it myself along the way so I can speak with more confidence about it.
Thanks BK and OMG…will find out tonight when I spray some on the interior and canopy frames on the Myrt. Only thing the bottle says is to let cure for a day.
Just got done. Hase called for half Naka and half Mitsu interior green. I added about 3-4% AK thinner just because.
Three light coats covered well, shot at around 20PSI from my NEO. Used about 3/4 of the large cup on the gun. Did the entire interior, cowl, wheel wells and canopy frames
I didn’t prime, as there won’t be any issues once she’s buttoned up (going with closed canopy). Laid out flat without any issues. Cleaned up with tap water and a run through of a couple cups of Iwata acrylic medium cleaner, with a back flush and wipedown.
Will see what the outside does when I get that far, as it is several colors and will require masking, Will prime exterior, probably with MM laquer primer.
Wow that’s not much thinner ! In one of the reviews I watched the reviewer said it was not real fussy about thinner amount though, must have been right, he eye balled it and gave no %. He also tried three or four different thinners, all worked pretty well, one was the AK thinner.
In one video the guy didn’t prime and masked it with blue tape later on and no paint lifted. He did a basic very generic free hand camo imitation on an old tank hull and the paint covered well. This wasn’t a build, he just used the hull to demo the paint. He had experience ( not good) with the old versions of AK acrylic and noted how improved this Gen 3 seemed to be. I think it was in his review where I got the notion this paint might be more Tamiya in nature than Vallejo MA is. But it seems priming is optional with this paint at any rate. He did note the leveling nature of the paint once dry. and the very good opacity and coverage. That’s the part that interests me. Thanks for your take !!
