Hi- new to modeling and I’m looking for suggestions on the best sand or berth to hold aircraft throughout the build. I mainly build WWII and modern aircraft.
I have looked at LMG but reviews are horrible.
Any help is appreciated
Ice
Ice
I know there are a number of laser cut wood ones on the market, but I have not always heard good things about them. I myself have built ones out of card board boxes. I have also seen people build them out of legos.
I have ordered a glue holder from this guy. I have seen others use his 3D printed jig, but only issue is he is in the UK so shipping can take a while.
I just have a block of Pelican Pick-and-Pluck foam that I use for that purpose. No need for extra padding on a wooden jig to keep from scratching your model. It also works well for stuffing inside places where you don’t want paint to get in. I have a large zip-loc freezer bag that I keep all of the various sizes of foam block in after using them, so they can be re-used.
for cheap just Cut and glue some cardboard or carve one from a block of styrofoam.
There are plastic and wood berths but I have no links for you. The wood one I have is from Czec republic
I’ve always made a simple ‘tripod’ type stand from a bent wire coat hanger and paperclips as tiny 90° ‘hooks.’ Easily adaptable to pretty much any size or configuration of model, allows 360° access for both building and painting, without having to touch or hold the model itself. (But simple to remove if needed.)
For a/c models they go on the stand once basic wing-to-fuselage assembly & cleanup is done – and usually don’t have to be removed until the model is finished, unless something like tricky landing gear alignment is required on a flat surface.
Cheap, versatile, and prevents pretty much any accidental wear and tear to the model! [Y][Y][Y]
