an old rare Airfix St Louis 74 gun ship was a gift to me so as soon as I got it I started it. It has been a real pleasure to build & is turning into a beauty. Here are some pictures from the start to today.
These are 5 of the 9 ships i have built this year. I have been busy, I feel like Floki on the Vikings series.
I will get back with more as I start the masts & rigging. I’m a little short of writing, but i do love to build. Thanks to Warship Guy for the St Louis. Gene
I’m also very impressed with your work but have a question about something else. Above your display cases are two prints of paddle or side wheeler river boats. Do you recall where you got them? I’m looking for something along those lines and from what I can see in your photo they look good.
Thanks for all you nice replies, guys. I’m just a shaky old guy, trying to keep the paint brush from doing circles.
jeffpez, Yes, I know where I got them. I can check but it was the Howard Steamboat Museum in Jeffersonville Ind., or Ohio, I will check. They Bill Reed’s paintings & are the best steamboat pictures you can find. They are from his steamboat picture book & it has a bunch of his paintings. A lot of his pictures are in the hotel bar in Marrietta Ohio. That is a neat place. If you like riverboats, that’s where to go’ I have a big print of his Betsy Ann framed in my model den I am still building it too. If you tap the picture it will enlarge beautifully.
Don & John, Thanks. John, it is MM gold enamel. It has done the gold on all 10 ships & there is still 1/2 left. It is the easiest trim paint I have ever used, because it hardly runs. It is great on the small gold work.
John, sometimes my hands get shaking so bad & I just hold my wrist on the table & brace it that way to paint. It works & I sure don’t want to stop painting or building. The shakes don’t bother the building unless I want to thread a needle. But then I have a needle threader.
One problem I had this time was painting the black raised bands ( forgot the name) as they had a groove on each side & the paint ran under the Tamiya tape. I burnished the tape down & still had problems. I like to paint the center first & then mask & hand paint the small stuff, bands etc.
One trick on masking tape edges is to seal those edges. Use either the color the masked band goes over, or a clear. Do that before painting the different color in the masked area. If there are any weak spots in the edge the leakage will not show, but the leakage then seals the leak, as long as it is a minor leak. That seal coating can be done either with a brush or airbrush.
Gosh TB, you are beginning to spell like me. We need to talk about riverboats some more. I just ran across a picture I took of the restored workboat Snyder in Marrietta. Have you been there? I got a bunch of riverboat stuff.
That Howard museum I mentioned above in Jefferson ville Ind. is right on the Ohio/ Ind. border just north of Louisville. They made a couple R E Lee’s there & floated them over the falls of the Ohio. I had never heard off them, until I saw them.
I also have a picture of my grandparents on a riverboat in the late 1800’s.
Hi kpnuts, No the St Louis is an old Airfix kit & is not available unless you have a special friend who gives it to you. Look on ebay as they come up now & then. I never was lucky enough to score one.
I just took these pictures to send to Warshipguy & figured I would put them here too. The St Louis might be the prettiest model of all the Airfix kits. I still have the sails to do, but am going crazy trying to put several furled sails on the 2 front mast’s
The last picture shows where I put a short wire in the mast to hold the spar on after the sail is put on. It works great.
Steve, you are my best fan along with Warshipguy. I want to see more of yours & it’s 11 ships in 11 months. I don’t rig like you, I’m crazy enough as it is.
