Aircraft in 1/35 Dio
Hi guys, I don’t know if this is the right forum to post this (Maybe it should be in the Amour or A/C forum).
Anyway, I would like to do a Dio of a gunned down aircraft being inspected by a scout car. However, I plan to do this Dio in scale 1/35. I haven’t seen aircrafts in scale 1/35. The closest I can get is scale 1/32.
What do you guys think? Is it fine to use a 1/32 with a 1/35? Pictures of Dios done on this topic would be helpful. Thanks [:)]
Sorry I dont have pics of a 1/35th scale aircraft dio, But 1/32nd and 1/35th scale items are used side by side in dios all the time. You should have no problems pulling this off. Good luck.
Only aircraft you can readily find in 35th are helicopters but I have seen several dios done using 32nd scale planes and 35th scale vehicles. The scale difference is a little bit but if you place the scout car away from the plane, the difference isn’t that noticible. If you are mixing scales for troops inspecting the plane, pick 1 scale for the equipment (rifles, packs, etc). Remember, humans come in many sizes but the guns are only issued in one.
Should work OK with a 1/32 Aircraft, especially in a crash scene Dio.
Regards, Rick
Thanks… Points taken note of. I’ll get down to work soon.
Post pics soon!
