Aircraft Colors vs.AeroMaster
Hi all -
I just ordered paint from Squadron. I specifically asked for AeroMaster, but was sent Aircraft Colors instead. Are these the same?
I sprayed the underside if my Do17 with RLM65, thinned with water, two drops of windex. It didn’t flow as smoothly as MM acrylics, and toward the end was actually separating in the cup!
End result on the A/C will be acceptable, I guess, but before I spray the upper surfaces, I’d like to know if I did something wrong, or if I should try something different.
Thanks in advance for any help.
Stinger
No, they are not the same. The original AeroMaster paints were manufactured by Floquil/Polly S for AeroMaster. These paints were discontinued after Testors took over operations of Floquil. The new AeroMaster paints under the Aircraft Colors label is made by Vellejo of Spain.
It might be possible that you overthinned the paint. The paints are packaged in eye droppers ready for airbrushing.
I recently called AeroMaster and asked if, indeed, their paint formula was being reproduced by Aircraft Colors (Color of Eagles) from Spain, and the person who answered said yes, they are the same. The paint bottles that I have been using (AircraftColors / Color of Eagles) have no reference to a company called Vajello.
So…where is the truth?
The paints work very well all the same. I would just like to be able to use the original Aeromasters to compare.
Thanks for the info though. I do really like Floquil.
Why is it that really good things have to change?
I recently bought to of the Aircraft colors and was told they were made by Vallejo also. Matter fact 2 of the shops here in town told me that and one even showed me some literature he had from his supplier…where it plainly says it. Oh well I have yet to use these…but I was told they are ready to shoot from the bottle. The main reason why I bought them is because they are “toned” down and should work well for all the 1/72nd AC I do
Because they don’t have to list the orignal manufacturer on the label for products. Many products you buy are not made by the company that slaps the label on. These companies get them from other third party manufacturers. If fact, it’s common to find competitors products made from the same factories these days. The fact that the paint came from Spain and is identical to the Model Air paints by Vallejo should convince you that the new Aeromaster paints are indeed made by Vallejo.
You still can get the original Aeromaster paint formulation if you want to compare them. If you are looking for the acrylic paints then get the Polly Scale paints. Same formulation as old Aeromaster but doesn’t come in the same colors that was available in the old Aeromaster paints. Aeromaster enamel is the same as Floquil enamel which sadly only is available in the railroad color line now.
