Airbrushing milky / haze finish after vanish
Hi All,
Have returned to modelling in my retirement since my last build in my teens.
Started by building some basic WW2 aircraft via hand painting followed by gross vanish, decals, another clear gloss, pin wash and finished with a clear Matt. No issues with paint reacting with vanish for a reasonable finish after such a long gap.
Have since moved to using an airbrush and had some issues with the paint finish turning milky or having a have. Not sure where the issue is and would like to ask for some advice?
Steps followed as per below:
  1. spray primer from a can (Tamiya)
  2. airbrushed model with thinned Tamiya acrylic
  3. gloss clear (Humbrol) applied via brush
  4. decals and softener
  5. clear gloss again - first issue seemed to have light areas like it was the primer (found advices online to applied another clear gross, this seemed to fix the problem)
  6. pin wash on panel lines
  7. applied clear Matt via spray can (Tamiya) - second issue it dried milky or had a haze on finish but on on the top side of the model that has a darker green paint, the underside seemed to to fine.
At a bit of a loss why this happened and would appreciate any advice.
Thanks.
Fortunately, I just posted a video on this topic. Look in the comments for a different theory that blames humidity for the problem. I think it can be both, or one, or the other. Humidity “fogging” looks more like a smooth, even film, like milk in water. Too much flattening agent looks like frost or snow.
Since your using an airbrush already,you should also airbrush your flat and gloss,it gives you much better control then flooding it on with a brush or spray can.
Alcad makes nice gloss and flat that airbrush straight out of the bottle
