Thanks for all the help guys. I ran the pressure up to 22, used a #5 nozzle and VOILA! FYI, I regularly use 12# pressure with a #1 or #3 for flat enamel painting.
Dave
Dave
Have you flatten down Future and airbrushed it? I never have and was thinking of using Model Master Acrylic flat base. but not sure.
I would imagine that would work without issue, I often use Future flattened with Tamiya Flat Base without any problems.
I’ve never used the MM Acryl flat base, but Tamiya’s works great, and you can adjust from semi-gloss to dead flat to OMFG it’s chalk!
This chart is from Swanny’s excellent article on Future:
Great article about Future, thanks for the heads-up
