AIRBRUSHING FUTURE??
hi all
as antbody tried airbrushing future with good results or is it to thin ?
many thx mick
I’ve done it with no problems. I put a couple of drops of isopropanol in there, but I’ve also done 100% Future. Best to try on a scrap piece first though so it doesn’t start running, but I found that it worked fine without trying to do anything special.
It’s not to thin, I even use some alcohol to thin it even more. Then you can get a very glossy coat.
I don’t even bother loading up the airbrush. It levels out nicley so I brush it on in thin coats.
Just take tare of the air bubbles that come out when brushing it on [;)]
I airbrush it, I use Tamiya acrylic thinner to thin it and it works like a charm!
Luis
Yes you’re right, have to check for those pesky little bubbles when brushing. Also be careful of pooling if brushing it on, that’s when nice thin coats work best.
