Airbrushes?
I’ve been brush painting since i started modeling and I think I want to try my hand at airbrushing, is there an ok one out there that can take the abuse of a kid using it and won’t break the bank?
Get a Paasche H model. It’s a single-action suction feed that uses interchangeable tips for different spray volumes, and can accept a small color cup or a large bottle. Even after you finally upgrade to one of the fancy double-actions, you will find this old workhorse will still be ideal for many jobs such as large-area coverage. It won’t handle German mottle on a 144th scale fighter, but you sure wouldn’t want to put olive drab on a 1/48th B-17 with the little one!
Yep, couldn’t agree more with Ashley.
When i got into airbrushing a couple of years ago, i bought the Paashe H.
I’ve since also bought a double action, but still use the H for any large projects, single colours or overcoats. You won’t regret it. Plus, it’s easy and simple to use - it’ll prove a good stepping stone for your next brush (if you ever decide you need another one that is).
Chris.
I know a lot of people who would agree with the above, but I might also recommend the Badger 155. It’s dual action and I found it very easy to learn with.
Nobody needs to start off with one airbrush and “upgrade” later. That is a pile of BS.
Get a good, double-action gravity-feed airbrush and learn to use it and you will not need to ever “upgrade” again.
Unless of course you want to. [;)]
Need and want aren’t always the same!
Looking back, I remembered that the most difficult thing about airbrushing as a kid was cleaning up. The spraying part was easy after about 3-4 spraying sessions.
Personally, I wouldn’t start with a low budget brush. Those are notoriously difficult to clean. You literally have to get out a tool set. And Lord help you if you lose one of their micro tools.
I’d recommend a brush in the $75-150 range from any of the big manufacturers. Badger, Iwata, Pasche. But I’d stay away from the “entry level” brushes unless one wants to spend more time taking the brush apart than the spraying itself.
Ditto on the clean up part! A good gravity feed brush like a Badger 100LG, which is all metal (tough), will waste less paint, and cleans easily without separate bottles. Plus you can get one for under 100 dollars. It will do fine detail pretty well, as well as decent coverage for broader sprays and it has a crown cap that does a good job of protecting the needle from bumps.
Good luck!
Chris
That’s my take on it as well!
I would add that you should you should get a recognised & reliable brand that has easily available & reasonably prices spares. The availability & price of replacement needles is usually a good indicator on spares availability / price.
Also, dont blow 99% of your budget on the brush & try to find a compressor as an afterthought, you will find that one comparative to your airbrush will most likley cost more than the airbrush itself!
Dito. I agree with Mike and Milairjunkie. But I will say internal instead of external mix, single or double action. A Badger 200 comes to mind. It is an internal mix, single action. See Don Wheeler’s review. Can be had in either siphon or gravity feed. And it is in the $60-70 range.
I started airbrushing with a Paasche H 20 some years ago. It did most everything that I want so I stayed with it for 20 years without thinking of an upgrade. However, the cleaning of the AB was a drag that kept me from using it often to build up on skill. I finally upgraded to an Iwata Eclipse HP-CS in 2008 and wished that I could have done that a long time ago. I understand that some modelers use the H or a Badger 350 and do not complain about the clean up like I did.
Unfortunately, no matter which AB you get, teaching a young child to clean it after use will be an uphill battle.
I would have to disagree with Mike, but just a little. I find double action airbrushes difficult to use. Might just be my dexterity. I’ve been fustrutated time and time again.
I prefer a good single action airbrush. I’ve been using the Badger 200. It has excellent spray ability, cleans easy and is simple to use.
If you have never used an airbrush before, I would really recommend the Badger 200. If you decide to get a double action later, the Badger 200 will still have plenty of uses.
-Jesse
It depends on what you expect to do with it.
Do you just want something to lay down a nice coat of paint? Then a simple external mix brush like a Paasche H or Badger 350 would do fine. And you’d never have to buy another brush.
Do you want a little more control and the ability to do fairly fine lines with a minimum of practice? Then an internal mix single action brush like the Badger 200NH would do fine. And you’d never have to buy another brush.
Do you want to be able to change the width of spray on the fly, and are you willing to put some time in learning to use it? And, would you like the ability to attach a bottle to the brush? Then a double action brush like the Badger Anthem would do fine. And you’d never have to buy another brush.
Do you want to do really fine lines and details? And, is a 1/3 ounce cup big enough? Then a double action gravity fed brush like the Badger Patriot would do fine.
All the airbrushes I mentioned are easy to clean and care for and all have their fans.
As was mentioned, don’t forget that the airbrush is only half the equation. You also need a regulated dry air source, and it could cost more than the brush.
HTH
Don
All of the above!
It all depends on your budget, and more importantly, your kid!
You can get a Badger 100LG or 105 Anthem from Dixie Art shipped to a US address for under $75. Great brush. Dual action does require a bit more control, but I own two of them (long story).
You can pick up a 200 detail brush from Badger’s Garage Sale with braided air hose, four fast blast adapters, a bottle and some paints (hobby paints, but good for practicing) for $44 + S&H. This is a single action, dial in the spray width and shoot brush. I only own one of those!
Or you can go back to Coast Airbrush and get a Paasche H set with all three heads, a bottle, color cup and braided hose for $46. I don’t have one of these, but I do have a Badger 350 clone, with is almost the same style brush. Hardly use it, myself.
The compressor is the part that is going to cost. If you have a garage style compressor, then maybe just use that with another hose to run into the house, and a regulator and moisture trap at the working end. Otherwise expect to pay $120 & up for an air supply. And another $25++ for a respirator.
Personally, I would go with the 105 Patriot as a be all, do all airbrush.
Whatever your decision, seriously consider using an acrylic like Tamiya. Soap and water clean up for hands, Windex with Ammonia for the airbrush. Watch out for the Flat Base, it isn’t a paint, but an additive!
I retired my Pasche H a number of years ago due to it’s high maintenance requirements.
I now am very happy with my Badger 155 (and 360).
DA isn’t that tough, else I wouldn’t be able to do it!
Like driving a stick…you just have to repeat it until you’re smooth at it!
If you don’t want to break the bank, I’d suggest a Badger. A 200NH would be a good starting point and even if you decide to get a double action, gravity feed later you’ll always find a use for it.
Here’s a couple of places where you can check them all out:
Dixie Art Supply or Coast Airbrush
Tony
Thanks for all the help, I picked one up at Harbor Freight for a few bucks. I’ll screw around with that to see if i like airbrushing. For somone working on a weekly allounce the price of the ones you were sugesting were a pretty big investment!
I am curious which harbor freight one you picked up. Did you get the airbrush compressor too?
i highly recommend harden and steenbeck airbrushes they r easy to use and very easy to clean check them out here www.chicagoairsupply.com i have the evolution good luck
I really like the look and the engineering of Harder and Steenbeck brushes (duh, German engineers!), but for the price, I can buy a Badger Patriot AND a siphon feed brush, or two Patriots (or 100LGs) one with fine and one with medium needle and head.
In your opinion, is the performance difference going to be enough that most folks would be able to justify an airbrush that’s twice as expensive?
Just curious!
Chris
