Airbrush
plese tell me about this kind of colour that what they need to melt this colour [|)]
Enamel = this almost make my air-brush broke up [B)]
Acrelic = Thinner?
What els??? thank you … and some body plese tell me how to reply the forum?
huh?
Colour and brush are enamel thin by melt. If broke thinner then body reply with q-tip. Change need tell with acrelic plese forum. Pngpeera_nazi need writing lesson so decay and mkish can comprehend question? Blind laquer with wheel dremel can help window tree. Enamel=thinner not problem.
M.
[8D] (I’m so funny aren’t I…)
Okay, I just found this thread. Murray, you are cruel. [:p]
Fade to Black…
lol I may need it
I’m just guessing at what you are looking for here Mr. pongpeera_nazi:
I think your trying to clean out your airbrush because your paint dried or “cured” inside. This is bad. Once Enamel paints dry, they are supposed to be permanent. Typically you cannot wash them away.
You may have to replace some parts of your airbrush.
Some acrylics can be washed away or cleaned off after drying.
To prevent this from happening again in the future, be sure to properly thin your paint and do not allow it to sit in your airbrush too long.
I typically use Rubbing Alchohol for Acrylics.
Enamel thinner varies based on the manufacturer’s reccomendation.
