Airbrush
[?] doen n e 1 know what u need to make an testers aztec airbrush work[?]
how to clean it, what atachments
vintage some help
Could you specify your question more?
Well makeing any airbrush work depends on the type of setup that you choose to use and there are two wasy to do this. The first way is to just simply hook up the airbrush to a large C02 canister and your done, that should last you about a year I personaly think its the easies way to do itt, the other way is to hook it up to an aircompressor but to do that you need a water trap to catch the condensation that is blown out with the air.
To clean an Aztec airbrush is very easy, since it comes with set spray width nozzels all you have to do is put a little paint thinner on them and clean it, also it helps to spray the tinner though the airbrush when your done too get rid of any accress paint.
Hope this helps,
The skies the limit,
V.A.
I don’t know anything about the Aztek, but check the airbrush section of the forum, there are a lot of people who can help you there.
