airbrush hose question
I have purchased an omni 4000 airbrush. will badger air hoses fit on this air rush. and do I need the 1/4 in compressor adapter if I use an air tank for an air source?
Yes, Badger hoses will fil the Omni. Thayer and Chandler airbrushes are made by Badger now.
Badger has two styles of hose. The vinyl hose has 1/8" connections on both ends and the braided hose has a 1/8" connector on one end and a 1/4" NPT connection on the other. To connect the vinyl hose to a compressor or tank you’ll need an adapter to go from 1/8" to 1/4". Badger sells them for about $4 or so. IT’s on this page: http://www.badgerairbrush.com/access2.htm and is part no. 50-023
