Hello,
Is there a way to convert a 27 gallon compressor used to run pneumatic tools for use with an airbrush? Thanks in advance.
Hello,
A Colman Powermate?
Anyway, you will need a regulator & filter which the compressor may or may not have fitted - the regulator unit will consist of a pressure guage & adjusting knob just before the air outlet & the filter is usually a glass bowl type affair, combined with or fitted close to the regulator, a bit like this;
If you already have one fitted, you will need to check that it can reduce the pressure down to what you require for airbrushing - somewhere between 10 > 30psi - if this is the case, all you will then need is a reducer/adapter so that you can connect you airbrush air hose to the regulator.
If you do not have a regulator, you will need to get hold of one, preferably with a filter (stops moisture getting to your airbrush) - just make certain that the regulators stated maximum input pressure exceeds your compressors maximum output by a sensible margin.
Thank you for the detailed information. I will begin looking into purchasing the necessary components. Yes, it is a Coleman Powermate. I am new to the airbrush experience so your assistance is greatly appreciated.
Take your time in spraying and enjoy the experance. Don’t be intemidated by the air brush. take some extra sheet plastic or art paper and practice and spray away. Great advice from other modeler.
