Air line tubeing for 1/35 scale
Hi all I am looking for a source for polly air line in differt colors , red , green , black . Some kits will come with the black but I havent seen other colors or even the black tubeing. I want to use for air line between truck and trailer and air brakes.
thanks
Jim
Jim:
You might try thin electrical wire instead, either from a well-stocked electronics store or scavenged from kaput electronic components. It’s a lot cheaper than “scale” aftermarket line, and has the advantage that, depending on the type and size of the wire inside, it will hold a great coil shape for the truck lines. The same quality makes it a great resource for any kind of detailing of engines, cockpits, and so forth.
If you need actual tubing, the wire can usually be pulled out leaving the hollow insulation. It’s also available in a variety of colors, though of course it can be painted as well.
Greg
