I just bought a Paasche “H” air brush and a testor air can. The coupling on the air brush hose is too large for the Testor can.
Can anyone let me know which air can I have to buy for the Paasche ‘H’.
I believe that all propellent cans are the same size. What you need is the attachment from Paasche to adapt the hose to the can and you should be able to get from the same location you got your A/B. Here is a pic of it.
Depending on how much you are going to use your A/B, you are probably going to quickly find that the propellent cans are a costly venture. If you can afford it, get yourself a compressor, you’ll save money in the long run.
Thanks.I am going to the Hobby store at lunch. Before investing in a compressor . I just want to test myself first with the .
The cans do add up. I used one can on one model and thats when I gave in and bought a compressor. I figured what the compressor cost me was the same as 6 cans of propellent.
