Again with the M113 HVMS...
I’ve just finished the main gun, and I’m going well with this project… While the putty is drying, I’ll start another part: The hull… I’ve cutted off the driver’s cupola and I’ll use it, the rest of the roof will be replaced, I’ve make a 42 mm diameter hole for the turret ring, but I want to modify the driver’s cupola, as it is very easy… I have part of the instructions of the Verlinden set, provided by ajlafleche… It says what to do with the cupola… but that part hasn’t been scanned complete… I only know that the periscopes around the cupola must be removed and the “hole” planked, and I think it’s the same for the periscope in the hatch (or not?.. I think it’s not possible) but the instructions are incomplete and the details can’t be read… Did anyone knows more about it?.. I think It’s a very easy part to work and I want to make it before starting with scratchbuilding the turret. Thanks in advance. Most regards.
Is there ajlafleche?.. The instructions I have have been provided by him… Currently I’m scratchbuilding the turret roof. I let dry the putty about 12 hours… What I’m suposed to do in these 12 hours?.. So I want to do something with the driver’s periscopes, but I can’t do it with the complete instructions… Thanks in advance.
