anyone make any aftermarket stuff for this one?
suggestions? kit any good? etc etc…
In general, it’s an excellent kit. Some faults have been discovered with the kit barrel however. Some other builders have corrected it but I know of no aftermarket correct barrel. Here’s my updated review and some construction notes of the kit
http://www.amps-armor.org/ampssite/reviews/showReview.aspx?ID=21&Type=FB
Here is mineI will echo what Roy said. It is a great kit. There is no aftermarket that I know for it either. , with notes on how to correct the barrel length as well. The only other thing you may want to change is the track. The kit tracks are only good for a late WWII piece. They were used more in the Korean War though. For a Korean War howitzer, either T80 steel block or T84 rubber block tracks are more appropriate. Both are made as separate kits by AFV Club. dragon also has both in various kits as well. I used Dragon T80 tracks on mine.
Good luck.
