admin read this
HEY,
This is not an urgent problem, but i thought id ask anyway. You know how the smilies are on the left side of the post box when you are typing a new post? Well i was wondering if you could make that happen when people type replies because i dont know the forum code or HTML code for the smilies and i sometimes want to put a smily in but i cant. Sorry if this is confusing. Hope you can cahnge this itty bitty problem. Thanks alot for hearin me out.
Randy
Replies are readily available in the “Reply to Topic” screen, just like if you were composing a new topic. If you want smilies in a reply, just click the “Reply to Topic” button.
demono69[}:)]
This should do for now.
In the Quick Reply window – the big square box at the bottom where you type your reply – look to the left and you should see two links.
Show Forum Code – pops open a window for reference.
Show Smilie List – pops open a window for smilies. From this window you can click on the smilie and it’ll add the code directly to the text box.
Please note, these two links need to pop open a window. So if you have a popup blocker on, well… I know for Google there is a way to allow certain popups through. I forget at the moment how to do it though.
Hope this helps.
David,
I tried the Smilie List with Google Blocker enabled, and it still came up fine. No worries on that end.
That’s good to know. Thank you for checking that out. I have the toolbar, but I don’t use the popup blocker since I need to see if popups are working.
